Activity Forums Adobe After Effects AE Audio Question
  • AE Audio Question
    Posted by Austin Reedy on December 9, 2009 at 10:38 pm
    Hi Everyone,
    I am doing some key work for a friend, and I’ve been given Quicktime files that I’m pulling into AE to key them with. Everything is fine except that upon importing the .mov’s, the audio is disappearing. When you look at the icon for the .mov in the program, it shows the audio waveform, however when I drop it into the composition I can’t get any audio to play, I can’t view the audio, and when I render it to a new .mov there is no audio available. Is there a setting I don’t know of? I don’t use AE often, so I really don’t know much about the settings, I really only want it for the keying stuff. Please let me know if I’m doing something, or if it cannot be avoided for some reason so I’ll have to sync it with the audio from the original .mov in another program. Thanks!
    Austin
    Austin Reedy replied 16 years, 9 months ago 2 Members · 3 Replies
  • Andy Dykstra
    December 9, 2009 at 10:53 pm
    If a layer or comp has audio, there is a little speaker icon in your timeline far to the left next to the eyeball icon for visible/invisible. If your footage is showing audio, but the render isn’t, check your render settings. I believe AE defaults to not outputting audio. In your render queue check the “output module” settings. My bet is changing a setting there is your answer.
    To play back audio in your comp, check your RAM preview settings, or use the period key on the numpad to playback just audio. AE can do some sweet stuff with audio, but I wouldn’t use it to edit your audio with.
    http://www.ghostrender.com
  • Austin Reedy
    December 9, 2009 at 10:59 pm
    it looks like (i figured out from reading a few other audio posted topics) that i was simply using space bar instead of 0 on the key pad, so once I used 0 it renders with audio available, so i think that should work. However, I have not rendered it out yet, what should i watch out for in the render settings to ensure the audio sounds okay?
  • Austin Reedy
    December 10, 2009 at 12:07 am
    that’s a great idea, and will probably save me some time too, I’ll pull my clips into FCP, then send the video (no audio) to AE, key what i need to key, then render, then you say to just pull the newly rendered clips back in over the old video and it should be fine? sounds great to me, thanks!
