Activity › Forums › Adobe After Effects › AE Assistance needed
  • AE Assistance needed
    Posted by Alain Ostiguy on June 5, 2016 at 6:50 pm
    Hello all,
    I’m having problem with After-effects CS6. For some unknown reason, It crashes on me as soon as I give it a command or as soon(lets say 3-4 seconds) as I import a picture/movieclip.
    It doesn’t crash if I just open it and let it be. I can also move a solid around but if I try to rotate it in Y, bang he’s out.
    The crash manifest itself this way :
    ”After effects CS6 has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.’‘
    It does look to me as if it doesn’t have enough resources, but it should not the case. It’s been years since I used After-effects at home. I made several updates on the system since then.
    Here is the window Event log:
    Faulting application name: AfterFX.exe, version: 11.0.4.2, time stamp: 0x52886341
    Faulting module name: MSVCR100.dll, version: 10.0.40219.1, time stamp: 0x4d5f034a
    Exception code: 0x40000015
    Fault offset: 0x00000000000761c9
    Faulting process id: 0x5a0
    Faulting application start time: 0x01d1bf58f4ccda82
    Faulting application path: C:\Program Files\Adobe\Adobe After Effects CS6\Support Files\AfterFX.exe
    Faulting module path: C:\Program Files\Adobe\Adobe After Effects CS6\Support Files\MSVCR100.dll
    Report Id: 402f0019-2b4c-11e6-808c-d43d7e9707d8
    Faulting package full name:
    Faulting package-relative application ID:
    Can anyone help me with this?
    Thank you very much.
    Alain Ostiguy replied 10 years, 3 months ago 2 Members · 2 Replies
  • Tudor “ted” jelescu
    June 6, 2016 at 8:05 am
    It would be helpful to know what version of Windows you’re running and the specs of your machine- processor, RAM, hdd setup…
    Also, you may want to post this on the Adobe forums.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Alain Ostiguy
    June 7, 2016 at 1:07 am
    Thank you for your reply Tudor, I solved my problem by trashing the AE preference file. 🙂
