Activity › Forums › Adobe After Effects › AE and Vegas Rendering Workflow Retardation
  • AE and Vegas Rendering Workflow Retardation
    Posted by Kevin Eugene on June 24, 2012 at 10:48 pm
    I shoot on a Canon DSLR (600D) at either 30 or 23.936 fps at 1920 x 1080.
    I use a mic on the camera for a reference track, and a Zoom for the actual sound track.
    Here’s where I am potentially being an idiot…
    I move the Canon clip into Sony Vegas Pro, and drag in the Zoom sound clip. I sync the sound and then delete the bad video sound. Great.
    Now I render it out using quicktime, no compression so I don’t lose anything. My original file is about 2 gig. My rendered file is now 30 gig. Ouch.
    Now I bring that into After Effects, add effects, titles, and color correction, and render that out using Quicktime, no compression. 30 gig. Ouch.
    Now I bring that into Sony Vegas again, add my music tracks, play with sound levels, etc.
    I render that out for YouTube as a .wmv, as I found that’s a faster render, least amount of loss, and least amount upload time. We’re back to 2 gig.
    Yes, this has got to be retarded, and I am sure it all falls down at the sound sync render.
    Assuming this is the correct forum, can anyone offer me some some guidance before I spend days mucking around with this?
    And as always, thank you.
    Kevin
    Kevin Eugene replied 14 years, 2 months ago 5 Members · 6 Replies
  • Tero Ahlfors
    June 25, 2012 at 7:29 am
    If you render uncompressed you’ll get huge files. Try making a motion jpeg or png compressed quicktime to bring the size down a bit.
  • Kevin Camp
    June 25, 2012 at 2:40 pm
    in addition to those codecs, apple’s prosres 422 or avid’s dnxhd would be good options too… dnxhd is free from avid and works with quicktime on both mac and pc.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Joseph W. bourke
    June 25, 2012 at 4:39 pm
    As the others have suggested, you may want to try one of the Motion JPEG Quicktime formats. I’ve had very good luck with Motion J-peg A at 90 percent quality. It holds up very well, and is way smaller than say, QT Animation uncompressed.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Kevin Eugene
    June 27, 2012 at 1:40 am
    Well thank you all.
    I think what I will do is just try rendering using all the different CODECs and see what happens.
    I am really trying to get my workflow down to sound sync, edit, after effects, etc., then just render, without all the interim rendering…seems like a lot of wasted time and space.
    Also, I may have a logic error, thinking the 600D raw material comes in at say, 2 gig, and I should be able to render out at about the same size, not 5 or ten times the size.
    Any, additional comments are welcome, and thank you all for the direction.
    Best Regards,
    Kevin
  • Michael Murphy
    June 27, 2012 at 3:20 am
    It comes in compressed. If you stayed in Adobe Premiere and After Effects, for example, you would not have to transcode or render in between steps.
    But as long as yopu have to transcode, redner, or export as an immediate step, you need to use an uncompressed codec, or at the worst a loss less compression. Otherwise you are introducing additional compression artifacts at each step of the way.
    Sort of like importing a JPEG, then re-saving the file as a JPEG over and over again while editing. You are progressively destroying the image data.
    So in Photoshop, for example, you read in a JPEG, then store as a DNG or Photoshop file, until final output as a JPEG for the web, or a print, etc.
    Storage is cheap right now. I just bought some Seagate Barracuda 2TB drives for $110 each. I have an external 3TB USB drive that was $150 about 6 months ago.
    There are probably cleaner workflows, but if you can afford to get rid of intermediate renderings when you are done with a project (won’t have to revisit intermediate steps, etc.), it is only a temporary hit with multiple files.
    Good luck!
    Michael
    Best,
    Michael
  • Kevin Eugene
    July 9, 2012 at 8:24 pm
    Thank to you all for your advices and good tips.
    I have bit the bullet and moved to Premier Pro and an AE workflow. Sooooo much better than the interim Sony Vegas stupid render cycle.
    I am still messing around with integration from AE to PPro, but all in all, I can see now how I can just pull my footage into PPro, no interim renders, and do a final render and save MEGA room.
    I also just purchased a 3TB drive for backups and whatnot.
    Again, thanks to all.
    Regards,
    Kevin
