Activity › Forums › Adobe After Effects › AE and SWF export?
  • AE and SWF export?
    Posted by Bob Karsner on February 19, 2009 at 4:02 pm
    I am attempting to convert a quicktime file to SWF using After Effects. Final file size is an issue. My origina QT file is 1 GB so I am exporting from QT and reducing the size to approximately 215 MB using H.264. When I export the file from AE using the SWF the file ends up being 680 MB. Any suggestions to reducing the end file size?
    Bob Karsner
    Bob Karsner replied 17 years, 7 months ago 2 Members · 4 Replies
  • David Bogie
    February 19, 2009 at 4:32 pm
    Most of these SWF questions end up being a simple user error, you are confusing a delivery format with a compression format. SWF is not a compression system. SWF leverages playback by using the CPU locally to recreate and display vectors and vectors are really small files.
    If you started with a movie, After Effects is simply going to be outputting very complex bitmap frames, not vector art. You gain nothing using SWF.
    bogiesan
  • Bob Karsner
    February 19, 2009 at 4:39 pm
    My client is requiring a SWF file format to use in some proprietary software. I have not used Flash… don’t have it. Any suggestions?
  • David Bogie
    February 19, 2009 at 7:58 pm
    that’s totally different. Your OP:
    SWF is a specialized file format but any SWF package of which I am aware also uses FLV without hesitation.
    Put SWF into the search at versiontracker.com. I came up with several possibilities.
    bogiesan
  • Bob Karsner
    February 19, 2009 at 11:05 pm
    Thanks David, I will give this a try.
    Bob
