Activity Forums Adobe After Effects AE and Premiere Pro Alpha Channel
  • AE and Premiere Pro Alpha Channel
    Posted by Marcelo Lewin on May 11, 2005 at 9:06 pm
    I can’t get the Alpha channel to show up in Premiere Pro (actually, I don’t know how to). I have a comp I rendered as a TGA sequence (RGB+Alpha / Pre-matted). The background is black. There are 2 layers. Both are text layers. One is white text the other is black text (like a shadow). I then animate the layers via text presets. After I render it, I import it into Premiere Pro 1.5. How do I make it to be transparent. I see the black background.
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
    Marcelo Lewin replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
