Activity Forums Adobe After Effects AE and AUDITION: can AE use markers created in Audition?
  • AE and AUDITION: can AE use markers created in Audition?
    Posted by Eric Chard on December 12, 2013 at 8:09 pm
    Title pretty much asks it:
    Can AE use markers created in Audition?
    So they show up when an audio clip is in the timeline?
    Do you have to save in a specific format?
    Thanks.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Ht Davis replied 10 years, 12 months ago 2 Members · 2 Replies
  • Eric Chard
    December 13, 2013 at 5:16 am
    Actually Dave, it works like a charm.
    The markers pictured were generated in Audition, displayed here in AE-CC:
  • Ht Davis
    May 11, 2015 at 7:45 pm
    as of cs6, you can use all manner of marker, but they will be converted to cue markers on the layer. there are scripts that will copy and paste, export etc, but you cannot elevate them to comp markers. I’ve heard that they are attempting to build the accessor for the Comp marker in CC, but I’ve really never needed that. So long as I can import other assets as layers, I can copy a layer to any comp I want, and I can copy the layer markers, I can essentially do all I need for audio. Getting disc markers to copy… …thats a tough one. I’ve never tried it. Supposedly the workflow is:
    copy paste from one to the other in AE, then send the new comp to premiere, then new sequence from comp. But… …this may as well just plant the comp as a clip, and use the markers as clip markers…
    It is possible to drag a sequence from one to the other, and I’ve not yet tried this. If the sequence already has the markers dropped on it, will they carry over when I drag only the sequence back to premiere? If so, then the markers would be there, I might just have to change their type. It would be good to test.
