Activity › Forums › DSLR Video › ? about XAVCs files from Sony A7s
  • ? about XAVCs files from Sony A7s
    Posted by James Dow on November 26, 2014 at 8:00 pm
    I recorded several clips in XAVCS on my new Sony A7s. When I look at the files on the camera I see both XAVCS and mp4s of the clips. When I try to import from SD card, or from Hard Drive backup Premiere CC only sees the MP4s. I have Brorsoft Video Converter, and I tried to transfer the one file that says AVCHD but there doesn’t seem to be anything there. My SD card has 3 folders:DCIM, MP_Root and Private. What am I missing?
    James Dow
    JPD
    James Dow replied 11 years, 9 months ago 2 Members · 3 Replies
  • James Dow
    November 26, 2014 at 8:28 pm
    I’m going to guess that the MP4s I’m seeing are really a container for the XAVCS files.
    JPD
  • Kaileen Fitzpatrick
    December 1, 2014 at 7:41 pm
    Here’s what i’ve been doing, though i’ve only had the cameras for 2 months.
    Going into it, i thought that Premiere CS6 was not going to be able to read the XAVC-S files. I found that was not the case. I have no trouble working with the MP4s cased in the XAVC-S file structure. Usually i just pull the MP4s right out of the Clips folder.
    One word of caution: In the past i have had trouble with the AVCHD file structure in that i was only importing the MTS files. I found in continuous run situations, where i was rolling for a few hours continously, that between each 12.5min file there was a 6-frame audio break. This happened because i removed the MTS files from their AVCHD file structure. If i would have left it intact, i would not have that problem. So i’ve been taking the same approach with the M4_Root folder–keeping the entire folder with all it’s contents for more major shoots. smaller things or short clips i just steal the MP4s out of the Clips folder.
    not sure if this is totally correct, but it’s been working for me and my projects so far.
  • James Dow
    December 3, 2014 at 7:06 pm
    Good to know. Thanks for the heads-up.
    JPD
