Activity Forums Adobe After Effects AE 7.0.1 on MacBook Pro
  • AE 7.0.1 on MacBook Pro
    Posted by Chris Stevens on April 30, 2007 at 7:36 am
    Since changing from Powerbook to MacBook Pro – AE 7.0.1 will not open? Do I have to upgrade to CS3? Have tried re-installing, but still no good – the ap goes through the motions of booting but disappears.
    G5 dual 2.7, OS10.4.8, 4G RAM
    Media100 HD V11.5 & Producer, AE 7
    3.6 terra RAID
    Kevin Camp replied 19 years, 4 months ago 2 Members · 1 Reply
  • Kevin Camp
    April 30, 2007 at 5:26 pm
    there have been reported issues with some older quicktime components givine ae7 fits. i noticed that you have media100 installed, you might make sure that you have the latest quicktime components from them.
    if you want to determine if third party quicktime components are the problem, go into the library (not the system library)/quicktime and move the components to a folder on you desktop. do the same in users/(username)/library/quicktime. then try opening ae7.
    if it works try putting back only the componenents you need, and try opening ae again. if it works, great; if not, then you’ll need to try to find updated components.
    if it’s not the components, reply back.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
