Activity Forums Adobe After Effects AE 7.0 no preview problem
  • AE 7.0 no preview problem
    Posted by Rafael Metz on April 17, 2008 at 10:48 pm
    Hi there,
    I switched back to AE 7.0 because AE CS3 has render/memory problems and there seems to be no working solution… :-< So, I have the following problem with 7.0. When I work on a project and I do change any value of an object e.g. position AE normally shows the effect of the value in the preview window. But my AE doesn´t - I scrub the mouse wheel, the position value changes but I do first see what happened to the object when I release the mouse (or pen). This is totally weird and you cannot work with that "feature" - how can that be fixed? Thanks and greetings Rafael MacPro 2.66 / 5GB RAM / AE7.0
    Rafael Metz replied 18 years, 4 months ago 21,894 Members · 1 Reply
  • Rafael Metz
    April 17, 2008 at 11:02 pm
    Thank you! It worked 🙂
