Activity Forums Adobe After Effects AE 7 Pro installation problem.
  • AE 7 Pro installation problem.
    Posted by Scotia2k7 on March 10, 2007 at 9:10 pm
    Hello! – I found this forum after purchasing After Effects 7 Pro – I read through the common FAQ’s, and a few posts/threads but since Im only *just* starting out with it, I wondered if I could ask directly for some help.
    Ive popped the disc in, and get the first splash – I click “install” – I get the choose language, then a quick flash of the “preparing to install” – then I wait, and wait, and wait…lol – If I ctrl, alt, del it tells me AEPro is running, but its not doing anything. I have a few suspicions, but to be honest – I was just so excited to buy it!
    Does the installer run system req’s checks? – could it be that mine just isnt up to running AE?
    Im running DELL INSPIRON 9300 laptop – Intel Pentium 4 @ 2.13GHz – Centrino,
    2GB RAM with 14GB hd space left? *eek?* Nvidia GeForce Go 6800 with 256Mb
    I currently have PhotoShop CS2, Studio8, Bryce 5 & Poser 6 installed – I wondered if apart from the fact my graphics card must be now out of date, there was a conflict in Render engines? Id really appreciate any help at all, Ive bought this, and am desperate to learn it!
    Thanks in advance,
    Scotia 😉
    “I would tell you the meaning of life, I discovered it some time ago – Sadly I forgot to write it down”
    Scotia2k7 replied 19 years, 6 months ago 2 Members · 2 Replies
  • Steve Morris
    March 11, 2007 at 3:32 am
    There probably is not much use installing it. You won’t be able to do anything once you get it installed. You will need to make some room or get a new drive.
  • Scotia2k7
    March 12, 2007 at 5:22 pm
    Hi there – thanks for the advice, I’ll follow it! – Any particular type of drive? (apart from a large one)- and can it be an external drive (since I have 40BG of stuff to shift otherwise?) – Do the other elements of my system seem ok? and finally, although I appreciate the advice, it kinda didnt explain *why* Im having the installation issues?
    Thanks in advance,
    Scotia
