Activity Forums Adobe After Effects AE 7 – Perspective Corner Pin
  • AE 7 – Perspective Corner Pin
    Posted by Casey Baugess on May 23, 2007 at 2:43 pm
    I am trying to do a simple motion track using the corner perspective pin feature and apply it to an AE type layer. When I apply it to the type layer, the type is being moved to the upper left corner of the window. Any idea why this is happening? It does the same thing when I place an illustrator type layer as well. I am using a mac and AE 7. I hope this is enough info for some help. Thanks.
    Casey Baugess replied 19 years, 3 months ago 3 Members · 4 Replies
  • Nicholas Toth
    May 23, 2007 at 2:52 pm
    Try to pre-comp it in a bigger comp with a transparent background.
    Then less overall perspective is added to the shape/shape.
  • Casey Baugess
    May 23, 2007 at 7:13 pm
    Thanks for the tip, but no luck. Anyone have any other suggestions?
  • Dan Ebberts
    May 23, 2007 at 7:40 pm
    Hmmm… AE treats type layers as being the full dimensions of the comp they’re in. Try precomping but reduce the dimensions of the precomp to just fit the text.
    Dan
  • Casey Baugess
    May 23, 2007 at 7:54 pm
    Got it! Thanks so much everyone.
