Activity Forums Adobe After Effects AE 7 freezes during startup splash.
  • AE 7 freezes during startup splash.
    Posted by Umer Zafar on October 9, 2007 at 10:51 am
    Hi there,
    I havent been able to run AE 7 recently because it stucks during its startup splash screen sequence when it is showing the amount of ram used e.g. “8 % of 496 MB ram used”.
    This happened simultaneously at my work place and at my home. I have uninstalled and reinstalled AE several times but its just not starting up.
    is it a virus or a hardware issue?
    If anyone can help me solve this issue, it will be a great relief. Thanks in advance. Bye.
    Umer Zafar replied 18 years, 11 months ago 4 Members · 6 Replies
  • Steve Roberts
    October 9, 2007 at 12:01 pm
    You mean 4096MB, not 496MB, right?
    I don’t think it’s a virus. First, I’d check to see if your systems meet the recommended hardware specs on the Adobe site. Then I’d try Adobe tech support, as I think they will solve installation issues for free … but it’s been a while since I’ve called tech support.
    By the way, please tell us your:
    OS version
    Processor speed
    Amount of RAM
    Anybody else?
  • Claudios
    October 9, 2007 at 12:50 pm
    I found this on an Adobe tech form but I no longer have the link to the actual posting.
    If you’re on a PC try this:
    Go to Control Panel
    Double click Adove Version Cue
    Start up AE
    This works for some people.
    Best of luck
  • Tim Kurkoski
    October 9, 2007 at 10:06 pm
    The most common cause of startup issues for AE7 is OpenGL. Try removing the OpenGL plug-in from the Plug-ins/Extensions folder.
    If that works, update the drivers for your video card, then put the plug-in back. If it fails again after you put the plug-in back, you can either:
    A) Get a new video card that supports OpenGL propertly.
    B) Just live without the OpenGL plug-in. You won’t be missing anything other than OpenGL acceleration.
  • Umer Zafar
    October 25, 2007 at 11:54 am
    Hello ClaudioS,
    Cant find Adobe Version cue in control panel. Any idea where else it can be. I am on windows xp pro and using ae 7 pro.
  • Umer Zafar
    October 25, 2007 at 12:02 pm
    Hello Steve,
    I am using
    Windows XP 64 bit wt service pack 2 installed
    Intel Core (TM) 2 CPU, 6300 @ 1.86GHz with 2 gb ram
  • Umer Zafar
    October 25, 2007 at 12:12 pm
    Hi there Timothy,
    i ve tried to run AE after removing opengl plugin but no effect. The lines on splash screen go quickly but i think it freezes after the opengl line has passed and the cleanup process starts.
    thanks for the help so far.
