Activity › Forums › Adobe After Effects › AE 7 does not see all of my RAM ?!!?!?
  • AE 7 does not see all of my RAM ?!!?!?
    Posted by Shane Mckinney on September 20, 2006 at 9:25 pm
    I have a G5 dual 2.5 PPC, I just recently upgradedf from 2.5 gigs of ram to 4.5 gigs ( i now have four 1gb sticks and the two 256 sticks that came with my machine).
    When I launch AE 7, on the start up screen it says so and so percentage of 3.0 gb of Ram.
    Also when I render AE tells me it is only using a percentage of 3.0 gigs?
    Can anyone tell me why this is and if there is any way to fix it?
    By the way when I check my memory in “About This Mac” the dimms show up and thier status says ok…
    Any help would be greatly appreciated as I bouht this ram to speed up AE!
    Shane Mckinney replied 20 years ago 2 Members · 2 Replies
  • Tim Kurkoski
    September 20, 2006 at 11:48 pm
    No application on Mac OS can address more than about 3 GB of RAM.
    Here’s the deal: OS X is a 32-bit operating system. 32 bits means the maximum amount of RAM that a single process (ie, and application) can address is 4 GB. Additionally, OS X requires applications to reserve a certain amount of memory space for OS-related functionality, so the maximum comes down to 3 GB.
    So this is correct, AE can only address a maximum of 3 GB of RAM on Mac OS. Why have more than that in your machine? You can run multiple applications at once, and they can each access up to 3 GB. So you can let Photoshop and AE hum along at the same time.
    How do you get Mac OS to get past that limit? You don’t, not until Apple releases a 64-bit version of OS X. Feel good that you have a Mac anyway, because Windows XP limits apps to 2 GB, though you can force it up to 3 GB with a registry hack (which has been known to cause stability issues from time to time). The 64-bit version of Windows XP can address a LOT more memory, allowing each application to access something like 16 GB of RAM. AE is not optimized for 64-bit, however, so even then it hits the 32-bit ceiling at 4 GB.
  • Shane Mckinney
    September 21, 2006 at 12:07 am
    Thanks for the info. That makes sense.
