Activity Forums Adobe After Effects AE 6.5.1 and Mac G5 Dual 2.7
  • AE 6.5.1 and Mac G5 Dual 2.7
    Posted by Mark Maness on June 30, 2005 at 2:29 pm
    Hey Gang…
    I’ve got a Mac G5 Dual 2.7 with 4.5 gig of RAM and I’m trying to run AE 6.5.1 on it, BUT I can only save my project ONCE, then when you finally render your project (that took hours to do because you have to do only a couple steps, save and restart AE), the menus are now greyed out and you can’t access the menus. You then have to use the keyboard shortcut Apple-Q to quit.
    And here’s another thing that’s not working properly. Memory used by AE. Mine only shows 2 gig of memory used but I have 4.5 gig total. Doesn’t more memory mean better performance?
    _______________________________
    Wayne Carey
    Schazam Productions
    Scott Frizzle replied 21 years, 2 months ago 4 Members · 3 Replies
  • Colin James
    June 30, 2005 at 2:49 pm
    sorry guy, *I could be wrong* but I think that 32bit applications like afx are limited to only taking advantage of 2 gigs of ram. even on a 64 bit os. Cinema4d too :/
  • Kelly Johnson
    June 30, 2005 at 4:35 pm
    Yes, due to the OS. Also, there were previous posts about the graying out problems. Search about two weeks ago forward and you should find the posts.
  • Scott Frizzle
    June 30, 2005 at 5:57 pm
    It is possible under Tiger for applications to access more than 2 gigs of RAM, but AE can’t do this yet. Apple’s Motion 2 can access more than 2 gigs of RAM under the same OS.
