Activity Forums Adobe After Effects AE 6.5 hdtv to final Cut HDV flicker
  • AE 6.5 hdtv to final Cut HDV flicker
    Posted by Nick Reiber on May 9, 2007 at 8:54 pm
    I have rendered out a motion graphics clip in hdtv size from after effects 6.5. I imported it into Final Cut in an HDV project and am noticing a very distracting flicker on the image when i preview it on my plasma. My frame rate is the same for the project and rendered comp. I am downsizing the file from the hdtv 1920/1080 to hdv 1440/1080, could that cause it? It’s most noticable in the whites. Any ideas?
    Erik Pontius replied 19 years, 3 months ago 2 Members · 1 Reply
  • Erik Pontius
    May 9, 2007 at 11:23 pm
    HD is upper field first. You can tell AE to render your HD comp using upper field see if that takes care of it.
    HD 1920×1080 uses square pixels. HDV is 1440×1080 using 1.33 pixel aspect…which stretches out to 1920×1080 square pixel.
    Erik
