Activity › Forums › Adobe After Effects › AE 6.5 and MacOS 10.4.1 Tiger
Posted by Mark Maness on June 20, 2005 at 7:59 pmIs anybody out there able to use this combination? I can’t seem to use it on a Dual 2.7 G5 with 4 1/2 gig of RAM. It only sees 2 gig of the RAM. I can’t save any files anytime. And after I render something, I can’t use the menus at all – they are all greyed out. It works fast, I just can’t save anything that I do. And yes, its reproducable on my system.
_______________________________
Wayne Carey
Schazam ProductionsBen List replied 20 years, 5 months ago 8 Members · 14 Replies -
Bill Marcellus
June 20, 2005 at 9:38 pmI have a dual 2.7 w/4 gigs of RAM and AE 6.5 is working fine for me. I know that this doesn’t help solve your problem but at least you know it CAN work properly.
Bill
Jerry Witt
June 21, 2005 at 8:08 amI’m having a similar problem.
Although I can save while I work, after I render, my AE menu is grayed out too. If I command-Q out of AE, I can save the project. And when I start it back up, all is well. This is under Tiger with 2 gigs of RAM using AE 6.5.1.
Wayne, are you by any chance running into this problem when you are using After Effects while leaving FCP 5 open? I THINK this is what is causing me my problem.
Basilisk
June 21, 2005 at 11:23 amsame combination here – if you haven’t got the 6.5.1 update for AE, I would try that. I think I found the update more stable and reliable
Mark Maness
June 21, 2005 at 1:29 pmI wish I could save… Sometimes I do have FCP 5.0 open and sometimes I don’t. But thanks, it was worth a shot.
Mark Maness
June 21, 2005 at 1:30 pmDone it! It doesn’t seem to be any different at all. But thanks for trying.
Nils Schneider
June 21, 2005 at 2:42 pmMaybe it’s worth trying to delete the AE prefs file, or just move it to the Desktop and relaunch AE. Doing this can solve weird problems like you have. Go to ~/Library/Preferences/ and delete/move the “Adobe After Effects 6.5 Prefs” file.
/Nils
Jerry Witt
June 21, 2005 at 3:55 pmSo Wayne, let me get this straight. You cannot save. At all? Ever? If you command Q out of AE you don’t have a chance to save?
Mark Maness
June 22, 2005 at 1:23 pmHey gang, thanks for all your help but nothing seems to work. I am at a total loss for words on this. The conclusion seems to be that I can’t use After Effects on that particular system until Adobe updates After Effects and I don’t see that happening anytime soon. I do know that Adobe better get on the ball, Apple Motion 2 is going to kill Adobe Affter Effects in the long run if Adobe doesn’t try to match it sometime soon.
Wayne Carey
Schazam Productions
