Activity Forums Adobe After Effects AE 3D Camera not motion blurring
  • AE 3D Camera not motion blurring
    Posted by Paul Curtis on April 1, 2012 at 9:19 am
    It’s been a while since i’ve been immersed in AE and part of me thinks this is a known issue.
    I have a camera panning across a camera projection, the cameras position isn’t moving, just the point of interest. Should this be motion blurred? I have every setting i can see turned on for Motion Blur but i’m not seeing anything.
    This is just a sanity check to see if i should or should not be seeing motion blur when only the cameras point of interest is moving?
    thanks
    Paul
    Brian Charles replied 14 years, 5 months ago 2 Members · 6 Replies
  • Brian Charles
    April 1, 2012 at 1:46 pm
    You need to turn on Motion Blur for the Comp.
  • Paul Curtis
    April 2, 2012 at 9:39 am
    Brian
    Yep, that’s all on.
    So you think that if you animate the point of interest for a camera view then i should see motion blur for it? Even though the camera itself isn’t moving?
    thanks
    Paul
  • Paul Curtis
    April 2, 2012 at 12:24 pm
    Actually just to add to this.
    It appears that when you project through a light onto a solid (camera projection), the outer shape of the solid will blur but the projected image inside will NOT blur.
    The source projecting layer will blur if i look at it.
    I assume this sounds like a bug to me. I’m on CS5 still, i wonder if anyone has CS5.5 and can confirm or deny whether it’s been fixed?
    thanks
    Paul
  • Brian Charles
    April 2, 2012 at 2:22 pm
    [Paul Curtis] “So you think that if you animate the point of interest for a camera view then i should see motion blur for it? Even though the camera itself isn’t moving?
    If the POI is moving quickly enough you should see motion blur, I am.
  • Paul Curtis
    April 2, 2012 at 2:57 pm
    Brian
    That’s really odd. I set up a bare bones project to test
    1) Camera static, fast moving POV key framed
    a) Add a solid – it’s motion blurred as expected
    b) Change solid to an image comp – blurred as expected
    c) Project from a light onto the solid – no blur except the edges
    So you’re seeing blur with c)?
    What version of AE are you using, i’m on CS5 still
    thanks
    Paul
  • Brian Charles
    April 2, 2012 at 3:01 pm
    [Paul Curtis] “c) Project from a light onto the solid – no blur except the edges
    Have not tested this way.
