Activity Forums Apple Final Cut Pro Legacy Advisable work flow for p2 HD
  • Advisable work flow for p2 HD
    Posted by Mccaincow on March 10, 2006 at 2:13 am
    I am running a fairly new dual core 2.3 GHZ G5 with 2 gigs of ram storing the footage on a 7200 rpm hard drive. I will be shooting clips with the HVX200 in 720p24N. What is the most advisable way to edit this footage in 720p FCP? I imported the clips off p2 cards and I have to render everything to get it to play back. Sould I be able to playback this stuff with no rendering? If not how complicated is a proxy edit?
    Jeremy Garchow replied 20 years, 5 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    March 10, 2006 at 3:47 am
    First, hit control-q and choose the DVCPROHD 720p24 easy set up. CREATE A NEW SEQUENCE (very important) drop the footage into this new timeline and you should be good to go.
    Do you have a capture card?
    Jeremy
