Advice sought on machine specifiaction
Hello,
First post, thanks for all the great information.
I am looking for a little advice on machine specification. After hovering between the Blackmagic Decklink HD Extreme and the Xena 2k I have decided to take the plunge and go for the Xena.A little background detailing my requirements. I need the box to capture HD SDI Duallink 4:4:4 out of a Sony F900R. I am being asked to do more and more green screen work and am frustrated with the compression from HDCAM
I usually, to save money build all of my own equipment. I have read the minimum requirements distributed by AJA but would like to hear real world experiences from people with DIY rigs. In my experience, often machines with less specifications will do the job fine. ( An example being Autodesk Maya, which also only certifies Quadro but I have been a power user for ten years and mainly use geforce cards which work fine.)
Is the Quadro really necessary? Will an gforce 9000 or GTX series do the job?
The raid will be 8* WD7500AYPS (750 gig 7200rpm 16mb cache)
connected to a RocketRAID 2320. I know SATA raids are not certified but this will easily pull the 400mbs required, right?I was intending to reuse one of my renderfarm workstations
ASUS P5KR motherboard with a Quadcore Q6600 CPU 4GIG Ram XP SP2
I understand the minimum spec states two physically separate chips but is this really necessary? I anyone running the xena 2k with a Q6600?
Oh yes and all of this will be going into a new Coolermaster Stacker 832, Case 1000w p/s
This box will not be used as an edit suite. I create visual effects with Maya and Fusion. As long as it can reliably capture 4:4:4 that will be enough.
I hope I have provided enough information for some feedback.
Any comments will be greatly appreciated. The shooting schedule for a project has been moved forward and I need to build this for the second week of Jan09.
Cheers
Mike
