Activity › Forums › Adobe After Effects › advice on this animation – see link
  • X(infinity) Media
    April 26, 2006 at 12:21 pm
    To be honest, it does look like a 3d stroke effect to me.
    Animating the bend, z depth, offset and other factors to create it.
    I would start with a straight line as the basis for the stroke. Go to where you want the move to finish and set it up there. Then move back to where you want the animation to start and set up that part. Scrub through and tweak as required.
    any advice I give is from my limited experience, therefore probably wrong…
    http://www.in-art-we-trust@deviantart.com
  • Steve Roberts
    April 26, 2006 at 1:32 pm
    It looks to me as if the coil doesn’t tighten, but moves away from camera instead.
