Activity Forums Maxon Cinema 4D Advice on Split Flap Rig
  • Advice on Split Flap Rig
    Posted by Carlos Angeli on June 5, 2012 at 12:29 pm
    I’m looking for a way to build a split-flap rig like the ones in old clocks and displays (https://www.youtube.com/watch?v=Iww7w9VD9f0). I’ve seen many tutorials for achieving this in After Effects, but I was expecting to build a physical rig within C4D.
    ¿Any thoughts on this? So far I’ve made my first attempts using dynamic tags with no luck.
    Carlos Angeli replied 14 years, 3 months ago 2 Members · 2 Replies
  • Randy Johnson
    June 6, 2012 at 9:51 am
    4250_flipper.c4d.zip
    Here is a starter file that might get you going in the right direction.
    /Randy
  • Carlos Angeli
    June 6, 2012 at 11:03 am
    Thanks Randy! Way much simpler than I what I did. I finally got to achieve a decent simulation using dynamics.
    I used a hinge to connect the bottom of the cards, and a motor to rotate the hole system. Also by using a top and bottom bumper I hold the position of the cards.
    On the bright side, I got a realistic difference in height between the cards which is also what I’m aiming for. Maybe a mix of the two methods will give me exactly what I want.
