Activity Forums Boris FX Particle Illusion Advice on rendering a default animation
  • Advice on rendering a default animation
    Posted by Aaron Cross on August 25, 2011 at 11:29 am
    Hi there I’m trying to render out an emitter. It is called fast squares party, and is in 09_03 bundle.
    Using the Apple Animation Codec seems to be the sharpest (all others look awfully blurred) but the particles actual animation seems to render in fluctuating bursts, like the cpu was struggling while rendering, and its created an effect where instead of evenly instantiating particles, it is emitting them almost like a sine wave fashion, with peaks and troughs of efficiency.
    Whats the best way to get a high quality render out of PI if the CPU appears to be choking whilst outputting a movie clip?
    I see apps called PIllusionRender, and PIllusionBatch in my PI application folder, do I need to use these?
    AaronC
    Alan Lorence replied 15 years ago 2 Members · 2 Replies
