Activity › Forums › Adobe Premiere Pro › advice on remote edit system/upgrade for conference videos and fast compressions
  • advice on remote edit system/upgrade for conference videos and fast compressions
    Posted by Glenn Walton on April 28, 2014 at 2:45 pm
    Need some great advice form CC peoples. Trying to figure out how I can get these edits out of my system and fast. I’ll be doing several on-site edits in various locations in the US with employee and CEO interviews along with some supporting shots. Pieces range from 5-15 minutes and we turn them around next day. Just finished the first one and it’s just not going to work….if I ever want to sleep again. our end product is a youtube ready video to upload and possibly a couple other compressions for client. easy enough right?
    the problem: working on a 2010 Macbook Pro 17″ i7 2.8GHz with 8GB ram. Nvidia GeForce GT 330M with 512MB. SSD internal. Camera op shooting to NanoFlash as ProRes – 30P 1920×1080. Ingest/edit fine. we do our program, add ID gfx, cutaways, music as needed. this last one 15 minutes. Export time was over 2 hours. in a crunch that hurts.
    solution: different machine? but something I can travel with. iMac with travel case? newer laptop? any third party options to speed it up? (matrox)?
    my setup currently for these remote edits include using a 2nd monitor via display port form the macbook pro as well to playback for client and real estate while editing.
    any help is much appreciated!
    Tim Kolb replied 12 years, 4 months ago 2 Members · 4 Replies
  • Tim Kolb
    April 28, 2014 at 3:00 pm
    Well…you could easily move to a newer laptop with better specs and improve your performance. You wouldn’t need an iMac, just double the RAM, a much better GPU… My Lenovo W520 has an i& that clocks slower than yours, but has a Quadro 2000 GPU and 16 GB of RAM.
    Also…the NanoFlash only records MPEG2…it has Sony’s hardware chip in it. It can wrap the file as .mov, but it isn’t ProRes.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Glenn Walton
    April 28, 2014 at 3:09 pm
    Thanks Tim for the response and confirming some suspicions. Having such great performance at the office with the Mac Pro and Quadro for making these files, it’s hard to make the transition and dramatically effect our workflow when editing on the road. Upgrading to a better performing laptop is the most logical as lugging around a iMac or something at least I can travel with makes things much harder. I believe too I’ll need something that has a supported video card to make use of MPE in premiere as well? I think that will dramatically improve things.
    Do you know if the Nano can record to the MPG then without wrapping it? would it make more sense to work within premiere with the native file? speeding up the flow even more?
    thanks again!
  • Glenn Walton
    April 28, 2014 at 3:27 pm
    Thanks Tim for the response and confirming some suspicions. Having such great performance at the office with the Mac Pro and Quadro for making these files, it’s hard to make the transition and dramatically effects our workflow when editing on the road. Grinds it to a halt in some ways.
    A laptop with better performance is a great solution for a lot of reasons. Lugging around an iMac isn’t the best scenario and knowing what some of the newer machines have I would expect better performance. I would imagine too I should look for a laptop that has a supported video card for MPE? If I’m not mistaken, that should help with tasks like this as well.
    I hadn’t realized the Nano had the sony chip and recorded MPG2 but wrapped it. Would it be possible or improve even more the whole process if I just took the native files as MPG2 into premiere? My goal is to just get closer to what I experience at the office. I can work with DSLR footage or other formats, edit a similar 15 minute piece and have a compression ready for YouTube in minutes so would love to try to get close to that level when working on these jobs on-site. thanks again
  • Tim Kolb
    May 11, 2014 at 6:26 pm
    The Nano will record a variety of file wrappers…mine is in a drawer around here somewhere and I need to look at it again, but I believe the wrappers were .mov, .mp4 and .mxf… Not certain if there are any limitations provided by data rate differences (is the mp4 wrapper available at data rates above 35 Mbits/s for instance…)
    I’ve had a few things come up that make me want to fire that unit up again anyway.
    TimK,
    Kolb Productions,
