Activity Forums Storage & Archiving Advice on RAID setup
  • Advice on RAID setup
    Posted by Sally Wilson on April 5, 2017 at 6:02 am
    I am just wanting some advice on whether or not the RAID system I’m thinking of using will be sufficient for my needs as im not great with technical stuff! Each year i edit a tv program that requires around 4T of storage for media and we need to upgrade our system.
    We have a 2015 Mac Book Pro (2 Thunderbolt + USB 3 ports) and was looking into getting the WD My Book Pro 12T system configured as RAID 1 (so i will have a mirrored – kind of backup!) aswell as getting another 4T External drive to back up everything onto via Time Machine as a “just in case the WD drives both fail” backup!
    RAID 5 and 6 systems would be great but unfortunately the budget won’t stretch quite that far at the moment. Given that we only ever utilise 3 – 4T of space for the entire show over the season would the above system be ok?
    Thanks in advance for the advice!
    Regards Sally
    Sally Wilson replied 9 years, 5 months ago 3 Members · 3 Replies
  • Bob Zelin
    April 5, 2017 at 12:44 pm
    Hi Sally –
    this is going to be a rude reply to you. However I hope this is helpful.
    This is a 4TB RAID array for Thunderbolt computers –
    https://eshop.macsales.com/item/OWC/TB2IVT04.0S/
    it’s $649
    are you actually telling me that you are doing a REAL TV SHOW and you don’t have $649 in your budget so you
    can edit your show. Do you work for free ?
    Bob Zelin
    Bob Zelin
    Rescue 1, Inc.
    bobzelin@icloud.com
  • Rainer Wirth
    April 6, 2017 at 11:48 am
    I stick with Bob,
    a Raid5 promise 4bay thunderbolt raid would give you more speed and enough redundancy together with your back-up routine – and it is not expensive.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Sally Wilson
    April 7, 2017 at 1:29 am
    Hi Rainer,
    Thanks for your response. Ill look into the OWC Raids. Ive got probably about $1500 – $2000 Australian dollars to work with so that should be a good option and then i can have Raid 5 also – and thanks for not being rude in your response.
    Regards Sally
