Activity Forums Apple Final Cut Pro Legacy Advice on Mixing SD and HDV formats
  • Advice on Mixing SD and HDV formats
    Posted by Laura Mcrae on August 14, 2009 at 3:59 pm
    Hi
    I am editing a project which was shot 1080i50 on a Sony Z1 camera and am editing natively in HDV using the appropriate HDV easy set up.
    I now also need to capture some archive footage which will be on a variety of formats DV, DVCAM and Digital Betacam, I have a Blackmagic card with SDI. What is the best approach to mix these formats with my existing HDV footage, what capture settings should I use etc.
    Do I need to recapture all my HDV footage transcoding it to something like ProRes or can I mix formats on the time line?
    Thanks in advance for your input.
    Laura
    John Fishback
    replied 17 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    August 14, 2009 at 4:23 pm
    Starting from scratch, I’d capture HDV as ProRes. However, as you’re already into it in HDV, I’d capture the new material as HDV when you upconvert with the Blackmagic card. IMHO it’s best to capture or transfer to just one codec and then edit with that.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
