Activity › Forums › Adobe After Effects › Advice on license plate retouch
Posted by Mark Levinson on May 9, 2017 at 2:19 pmHi,
I was hoping to get some feedback on how you would approach removing the type from the license plate in this sequence. Not sure the best way to go with the various light effects/flares going on here. The shot is only about 2 seconds but there is a lot going on around the plate.
thanks.
Mark Levinson replied 9 years, 3 months ago 4 Members · 5 Replies -
Mark Levinson
May 9, 2017 at 4:27 pmLooks like it would have been better for me to include a link to the clip itself. Please see below:
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Jeff Hinkle
May 9, 2017 at 8:24 pmI’m with Dave and Richard. On the clips, between the lights and the short duration, I can’t make out anything. I can sort of make out the plate on the stills, but I have to really make an effort and even then I’m not 100% sure of any letters. But I can tell it’s a Mini Cooper, so that’s one mystery solved.
It is easier to destroy than to create.
More fun, too. -
Kevin Camin
May 10, 2017 at 3:52 amI get it. Some clients are absolute about legal issues.
Does this work?
If so, all I did was track the car and I used that to create a moving matte for a blurred version of the license plate. The matte was basically a highly feather ellipse–there is so much going on and so much feathering that you can’t really tell the flares are getting softened in those areas.
Best regards,
Kevin Camin
Mark Levinson
May 10, 2017 at 1:54 pmTHANK YOU KEVIN!
Yes, you are the first person to actually acknowledge that it is a client thing, and you can see it more clearly on the pro res version of the file. Your solution is perfect, thanks. There are other more prominent shots of the license plate but this one had so much more going on around it.
