Activity Forums Apple Final Cut Pro Legacy Advice on going from FCP sequence to WMV file using flip4mac?
  • Advice on going from FCP sequence to WMV file using flip4mac?
    Posted by Martin Mcgagh on March 9, 2016 at 11:33 pm
    Hi, I’m rushing to meet a tight deadline, I wonder can you save me some trial and error? I’m working on exporting a decent WMV file using flip4mac (basic Studio version), beginning with a QT .mov exported from FCP7. All resulting WMV’s so far have been of poor quality and perhaps too small for the intended presentation mode (projected using Powerpoint). I’ve got Compressor 3.5.3 at my disposal also if that helps. Any tips much appreciated.
    Martin Mcgagh replied 10 years, 6 months ago 2 Members · 4 Replies
  • John Rofrano
    March 10, 2016 at 1:30 am
    Try SmartConverter from the Apple App Store. It’s free and handles WMV files quite well. There is also a Pro version but I’ve never used it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasstsoftware.com
  • Martin Mcgagh
    March 10, 2016 at 12:53 pm
    Thanks jr, just did a quick test and it looks like it’s gonna work fine. I have one more quick question if you don’t mind.. When converting to a WMV like this, what are the advised FCP sequence settings as regards Field Dominance (ie. Upper, Lower, or None) to avoid any field issues in the conversion? Perhaps lowering the frame size to 960×720 is a help in this regard also?
  • John Rofrano
    March 10, 2016 at 8:13 pm
    [Dave LaRonde] “Don’t use interlacing; computers don’t like interlacing.”
    +1
    Yea, interlacing is only for broadcast or DVD playback on an interlaced TV. All web media and computer playback should be rendered progressive (no fields).
    [Martin McGagh] “Perhaps lowering the frame size to 960×720 is a help in this regard also?”
    Most Windows computers should be able to handle 720p. I would not use 1080 as this can stutter on some older systems.
    ~jr
  • Martin Mcgagh
    March 10, 2016 at 11:11 pm
    Thanks jr, much appreciated.
