Activity Forums Maxon Cinema 4D Advice on buying a mac for c4d
  • Advice on buying a mac for c4d
    Posted by Emmet Reddy on December 5, 2014 at 11:05 am
    Hi guys I’m thinking of buying a refurbished mac i have two options one i can afford and the other i can afford at at stretch but is it worth it?
    these are the specs.
    Im also considering an iMac or a new black tube mac pro, but i know ill have to buy extra bits to get my aja kona card to work with those.
    When it comes to using C4d I’m ok but the fire power I need can confuse me. These guys will custom build the mac so to cut the price I’m thinking to ask for one main drive 500gb for my os and applications. For the ram would i be better off going for the 12gb and buying more myself and installing? then theres the cores (12 Core 2.66GHz Intel Xeon (12 real cores)) or 12 Core 3.46GHz Intel Xeon (12 Actual Cores). for use in C4d will i have a big difference between 2.66 and 3.46 Ghz ? also how would these machines compare i.e. the 12 Core 3.46GHz Intel Xeon to the new iMac i5 3.8 GHz or the new black tube mac pro 6-core machines. I know this is a lot of questions but any advice is greatly appreciated cheers.
    I can afford
    Apple Mac Pro 5,1
    2TB 7200RPM Hard drive
    12GB DDR3 ECC RAM
    Bluetooth and Wifi
    Nvidia GT120 512MB GPU
    or this one i can afford but at a stretch
    Apple Mac Pro 5,1
    48GB DDR3 ECC RAM
    512GB Flash PCIe Storage
    4TB 7200RPM Hard drive
    Bluetooth and Wifi
    ATI 5770 1GB GPU
    Emmet Reddy replied 11 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 5, 2014 at 9:07 pm
    Single core speed and graphics card make for your viewport speed so the 3.46 machine will be better on both counts as the 5770 outperforms the 120 too, single core speed will also make single core pre-render functions faster too
    Render speed is number of cores and speed so the 3.46 will be faster there too.
    There will be a difference between the 2.66 and the 3.46 but whether that is enough for you is up to you. Are you aware of the cinebench scores on cbscores.com for comparison?
    Might be cheaper to get a 5,1 2.4 8-core and do an OWC upgrade (maybe)
  • Emmet Reddy
    December 6, 2014 at 10:37 am
    Thanks Brian thats very helpful the cbscores are also very useful. All the best Emmet
