Activity Forums Adobe Premiere Pro Advice Needed– Premiere Pro Native Support and other things
  • Advice Needed– Premiere Pro Native Support and other things
    Posted by Andrew Hays on October 23, 2011 at 10:57 pm
    Need some advice on which cameras and which HD acquisition formats work natively with Premiere Pro (i.e. you don’t need to transcode, re-wrap, or render the footage (once it’s on the timeline)). I’ve personally only used AVCHD and that codec is not very edit-friendly. It’s somewhat sluggish without rendering the footage first. Our business needs something that we can edit with fast, and not much render time. We are looking at a $5,000 budget for each camera. going to be getting two cameras. we are leaning more towards file-based formats. We are also considering LTO drives for the Mac. Any advice on that would be helpful as well.
    Things are gettin’ interesting…
    Tom Daigon replied 13 years, 12 months ago 5 Members · 6 Replies
  • Tom Daigon
    October 23, 2011 at 11:23 pm
    Be forewarned that EVERYTHING is rendered when exporting at the end of a session. Premiere is different then FCP which stitches together all its renders for a fast output. Ive used P2 and Prores recently and for straight cutting they needed no rendering during the edit process.Owners of various models of Mac Pros seem to report different playback performance with certain formats. Of course any supers or dynamic links with AE will require rendering time. But at the end of the session, when you export the video, all the stuff on the timeline will be rendered out to a file. In this way its different than FCP. This is how an Adobe technician explained it to me.
    “What you’re looking for is what we commonly refer to as smart rendering, and it doesn’t exist in PPro. That’s a Final Cut ‘ism, where it splices rendered data from the preview QT files into the final render. Keep in mind that’s a QuickTime centric feature, & doesn’t translate automatically to all file formats.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Angelo Lorenzo
    October 23, 2011 at 11:51 pm
    https://www.adobe.com/products/premiere/features.html#categorylens_c972_featureset_797a
    This is for Premiere CS5.5
    What version of Premiere Pro are you running? If it’s CS5 and above, are you using compatible nVidia cards? The hardware accelerated playback engine seems to work best with MPEG based camera codecs (h.264,AVCHD, XDCAM, etc). They all seem to work equally well.
    Have you also tried looking at playback performance with resolution turned down? I usually set playback resolution for 1080 footage to 1/2 or 1/4 if I have other programs open.
    What are the specs on your editing station? Perhaps there is a deficiency we can solve there as well.
  • Chris Tompkins
    October 24, 2011 at 12:37 pm
    We shoot AVC-Intra on P2.
    APP brings in the native files and plays sequence w/o render.
    Look @ the HPX250 for your camera choice. You’ll need to budget for P2 Cards though.
    Chris Tompkins
    Video Atlanta LLC
  • David Cherniack
    October 24, 2011 at 11:56 pm
    Tom, please see my response in the other thread.
    https://forums.creativecow.net/readpost/3/917524
    David
    AllinOneFilms.com
  • Andrew Hays
    September 6, 2012 at 3:56 am
    Thank you all for your replies. My boss unfortunately purchased two iMacs and FCPX instead of PPro for work. We ended up going with the JVC HM150U’s which are pretty good little cameras for what we do. I personally run CS5.5 at the moment and will be upgrading to CS6 and a PC in about a year.
    ..and knowing is half the battle.
  • Tom Daigon
    September 6, 2012 at 12:33 pm
    Bummer about FCPX, but glad to hear that at least at home you will have Adobe to work with.
    Tom Daigon
    https://www.youtube.com/watch?v=XRIg6h-LIm0 (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
