Activity Forums Adobe Illustrator Advice needed, Logo Transparency
  • Advice needed, Logo Transparency
    Posted by Robert Hoisan on July 9, 2011 at 1:38 pm
    Hi!
    I am a total newbie to Illustrator, i usually take the vector files created in it and animate them in After Effects… But this time i have a real headache, I am trying to use a Logo for a client but the file he gave me has some paths filled with white above some letters and i need the white gone so it will be transparent. If i delete the paths or make them with no fill it shows the underneath letters , but the letters don’t have transparent holes in them. Like the letter “g” for example, the circle in it is filled with color and i need a transparent hole…
    I attach the file, i am sure it’s a 2 minutes job, if just someone can show me will be great.
    2543_logo.ai.zip
    Robert Hoisan
    Motion Graphics Artist
    Robert Hoisan replied 15 years, 1 month ago 2 Members · 3 Replies
  • Robert Hoisan
    July 9, 2011 at 8:56 pm
    Double post, sorry about that.
    Robert Hoisan
  • Les Nemeth
    July 10, 2011 at 8:38 am
    First of all, select the whole logo and ungroup it (since everything is a single group).
    Now select the inner and outer part of the objects that are filled with white. For example select the outer (gray) part of the letter O and its inner white filling. So you have 2 separate objects selected now (the outer O and the inner white filling.) Right click > Make Compound Path.
    Do this for all objects that you want the white part to be transparent.
  • Robert Hoisan
    July 10, 2011 at 8:42 am
    Great! Thanks a lot!
    Robert Hoisan
