Activity Forums Apple Final Cut Pro Legacy advice make a s clean sharp credit roller?
  • advice make a s clean sharp credit roller?
    Posted by Emmet Reddy on March 25, 2009 at 9:54 am
    hi im cutting a short movie and im doing the roller but it always looks a bit flickery using the boris title crawl so i made up a roller in photoshsop because the client wants some logos on the roller and i dont think i can do that in boris title crawl? anyway it still looks a bit flickery has anybody any advice on creating a clean sharp roller with some logos in the roller, im also working in xdcam thanks emmet?
    Emmet Reddy replied 17 years, 5 months ago 3 Members · 3 Replies
  • Michael Gissing
    March 25, 2009 at 10:53 am
    What are your sequence settings? Interlaced or Progressive?
  • Dave Berezai
    March 25, 2009 at 11:21 am
    Hi Emmet,
    Are you viewing the roller on a CRT? If so it sounds like your type is ‘flickering’ between two scan line as it rolls upwards. The best way to get around this is to blur the text by 1 pixel (Vertically) so that the type blurs across the scan lines creating a smooth roll. Its also a good idea to set your type to continuously rasterize so that the type is as sharp as possible. I have created many rollers for broadcast in this manner and they always pass with flying colours!
    Now unfortunately Borris doesn’t have these features but After Effects does. After Effects will also allow you to implement your graphical elements and parent them to your type. Hope this helps and good luck with your project.
    Dave Berezai
  • Emmet Reddy
    March 27, 2009 at 3:24 pm
    yes im viewing on a crt, i will give it a go in after fx
    Thanks Emmet
