Activity › Forums › Apple Final Cut Pro Legacy › Advice for Fast Motion Graphics Comping in FCP
  • Advice for Fast Motion Graphics Comping in FCP
    Posted by Mark Laskowski on November 1, 2007 at 10:58 pm
    I’m looking for advice on the best way to set-up FCP in order to do fast motion graphics comps.
    I work primarily on 2-minute and half-hour DRTV projects (infomercials) and begin by having my clients provide me a low-res graphicless version of their edited project. I’d like to know the best settings to use in FCP to be able to work quickly with a minimum amount of render time. I’d like to set-up the project in FCP and create graphic elements in Motion, and drop them into my FCP sequence. For this first draft I don’t mind working in a lower resolution (like half of full-resolution) as it keeps file sizes reasonable for the internet. My primary goal for a first-draft is to work quickly, and do as much work as possible in real-time.
    Any advice is greatly appreciated.
    –Mark
    Mark Laskowski http://www.laskowskiDesign.com
    Main Hardware:
    24″ iMac (2.8GHz Intel Core 2 Extreme, 2GB, 500GB HD, ATI Radeon HD 2600 PRO with 256MB memory)
    Main Software:
    Final Cut Studio 2 (FCP 6, Motion 3)
    Francois Stark replied 18 years, 11 months ago 2 Members · 1 Reply
  • Francois Stark
    November 7, 2007 at 10:08 am
    FCP works best in DV resolution. 720×576 in PAL.
    Very good performance, you wont get it to render much faster if you go to a lower res.
    If you need a small version for the web, export your timeline to a quicktime movie and send it to compressor. There you can reduce size for distribution.
    Unfortunately Motion renders slowly, there’s no way around that.
    Regards
    francois
