Activity Forums AJA Video Systems Advice for COMPOSITE input
  • Advice for COMPOSITE input
    Posted by Bobby Abate on March 9, 2010 at 1:00 pm
    I want to take a composite signal from an old VHS camera and put it into the KI PRO DECK. I know the KI PRO only has component inputs. Is it really as simple as just plugging it into the Green Component – or do I have to use a Composite to Component converter?
    If I do have to use a composite to component converter – what’s the best (and the cheapest..)?
    It seems a little pointless to convert a composite signal only to have the KI convert it again, but if it must be done – I’d like to know how to do it cheaply.
    BB
    -Bobby
    Gary Adcock replied 16 years, 5 months ago 4 Members · 5 Replies
  • Jeremy Garchow
    March 9, 2010 at 3:08 pm
    Aja has a converter, or find a VHS deck w/component.
  • Alex Desrial
    March 11, 2010 at 4:40 pm
    Hi JG,
    I also want to try to use the old camera which has only composite output , convert it to component or SDI.. and record with Kipro.
    Have you try the way…” How good is the quality we can get with this ? ”
    Can we still say we get 10 bit video with it ?
    Thank you for the share JG
    Best Regards
    Alex
    Alex Desrial
    MediaIntegra – Jakarta
  • Jeremy Garchow
    March 11, 2010 at 7:25 pm
    [Alex Desrial] “” How good is the quality we can get with this ? ” “
    It’s still going to originate from a composite signal, even if you convert it to a higher bandwidth video signal.
    Jeremy
  • Alex Desrial
    March 12, 2010 at 6:19 am
    Hi JG,
    Yes I know, it is still originate on composite.
    But wondering if you have tried it and help get informed the quality as i never record from composite signal with Kipro yet .
    Thanks Jeremy
    Alex Desrial
  • Gary Adcock
    March 12, 2010 at 11:42 am
    [Alex Desrial] “But wondering if you have tried it and help get informed the quality as i never record from composite signal with Kipro yet . “
    Quality would depend on a number of factors, but my guess is
    the comp signal is limited in resolution based on the camera but most likely less than 200 lines
    your colorspace is also limited in Composite mode vs component.
    https://en.wikipedia.org/wiki/Component_video#Component_versus_composite
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
