Advice for Canon Vixia HF R20 Record Settings
We are experimenting with some “commodity hardware” for shooting corporate events and found that the relatively low priced Canon Vixia HF R20 encodes using h.264 in mp4 container which is useful for us.
My recording options are:
– 60i
– “PF30” which is described as “30 frames per second, progressive” but then it goes on to say “Using this frame rate, video is recorded as 60i”
– “PF24” which is described as “24 frames per second, progressive. Using this frame rate will give your recordings a cinematic look.” but then it goes on to say “Using this frame rate, video is recorded as 60i”I will likely pull these into Vegas for some touch up, but I’d like to avoid as much re-encoding time as possible.
Ultimately, we will re-encode these to a number of formats exclusively for the web:
– 240p
– 320p
– 480p
– 720pThanks in advance for any help you can provide!!
