Activity Forums Apple Final Cut Pro Legacy Advice before updating to Lion
  • Advice before updating to Lion
    Posted by Scott Patterson on April 2, 2014 at 10:48 pm
    Hi there,
    still on snow leopard because my tower and FCP 7 are working steady for years.
    I need to start updating, mainly because I will need Adobe CC soon and I need at least 10.7 and even 10.7.4 to use after effects it seems.
    I have too many ongoing FCP projects and I’m hesitant to go to Lion and have things not work out.
    Not clear on how I can go about installing Lion on a separate drive.
    Any insight, advice, and instructions would be greatly appreciated.
    scott
    Also concerned that my ATI Radeon HD 5770 card won’t work with AE once I install Creative Cloud
    Mac Pro info:
    Apple Mac Pro “Eight Core” 2.8 (2008)
    Model Name: Mac Pro
    Model Identifier: MacPro3,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.8 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    L2 Cache (per processor): 12 MB
    Memory: 10 GB
    Patrick Givens replied 12 years, 5 months ago 6 Members · 8 Replies
  • 8 Replies
  • Steve Eisen
    April 2, 2014 at 11:51 pm
    Purchase 3 more hard drives.
    Clone your Snow Leopard Start Up. Startup that drive whenever you need FCP 7. The clone will be your back up.
    Personally, I would skip Lion and Mountain Lion and go straight to Mavericks. Do fresh installs on 10.9 including Creative Cloud.
    Your graphics card is fine for CC. You will have no problems. Once again, use the third hard drive to clone OS 10.9 and use that as a backup.
    Use 2 drive bays for your startup drives 10.6 and 10.9.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Shane Ross
    April 2, 2014 at 11:57 pm
    I disagree. Lion isn’t as solid as Mountain Lion…and Mavericks was written without ANY consideration for FCP 7. Many have reported issues with it. But FCP 7 is solid on Mountain Lion, as is Adobe CC, and Avid MC7.
    Shane
    Little Frog Post
  • Mark Suszko
    April 3, 2014 at 3:57 pm
    I’m more with Shane on this. My preferred way to go: clone a clean Mountain Lion/ FCS3 install, save offline as a backup. Copy it to a new, empty boot drive, with a separate partition for Mountain Lion and a separate partition for Mavericks. Boot into whichever you need. media as always goes to its own external RAID, I would go with a RAID6.
  • Scott Patterson
    April 3, 2014 at 6:07 pm
    Thanks for the advice. I had already bought and downloaded the Lion update. Just realized that if I do the partition route, Lion partition will be a clean slate and I will have to install and copy over tons of stuff, and I don’t even have enough space left on boot drive to fit these duplicates. I don’t want to have it on an external drive.
    Looks like I will have to take the slight risk of doing a regular update to Lion, and if FCP 7 doesn’t work, I’ll have to wipe clean and find a way to go back to Snow Leopard.
    Guess once I get Adobe CC and learn Premier I can catch up and be on Mavericks.
    any other thoughts welcome.
    scott
  • Steve Eisen
    April 3, 2014 at 7:33 pm
    Hard drives are very inexpensive. Clean installs will yield less problems.
    Premiere Pro is an easy transition from FCP.
    Steve Eisen
    Vice President
  • Roger Poole
    April 4, 2014 at 2:01 pm
    I agree with many of the comments here, I would never compromise a working system by updating the O.S. I have several boot options. Disk one has FCS2 running Snow Leopard, I keep it because I find it much more stable than FCS3 (FCP7). Disk 2 is partitioned into two. Partition 1 has FCS2 running Lion. Partition 2 has FCPX 10.0.9 running under Mountain Lion, I haven’t gone the FCPX 10.1 route because of Mavericks.
    When installing multiple boot disks it’s easy to bring over your documents and files of your choice from another disk using Migration assistant.
    One important thing to do when running multiple boot drives is to manage indexing because being boot drives they are journaled and so with 3 boot disks and booted into Disk A, it will constantly indexing Disks B & C. To prevent this activity which will slow everything down go to system preferences, Spotlight>Privacy and drag in Disks B and C. Repeat this for all Boot disks, for example if Booted into Disk C put Disks A and D into the Spotlight privacy panel, etc.
    This setup works great for me. I still have my old trusted and optimized systems yet have the flexibility to use the newer ones without compromising older Apps. Yeah, some people have managed to get FCP7 running on Mavericks but it’s a bit of a dog so what’s the point.
  • Roger Poole
    April 7, 2014 at 1:44 am
    Correction, partition 1 has FCS3 FCP7.0.3 running under Lion.
  • Patrick Givens
    April 7, 2014 at 7:14 pm
    I’ve been using 10.7.5 on two Mac Pros (2010 – 2 x 2.4 quad core w/ATI Radeon HD 5870) running FCP 7 and CS6 for a couple of years now with very few issues. Both machines are work horses and sure FCP crashes once every blue moon (it’s always done that since version 1), and compressor hasn’t worked well for awhile now (adobe media encoder is much better anyway). I would, however, beware of upgrading to Mavericks if you plan on using FCP extensively.
    •pgivens•
