Activity Forums VEGAS Pro ADVC can’t connect
  • ADVC can’t connect
    Posted by Geoffrey Mee on December 12, 2005 at 6:17 pm
    I cant get Canopus ADVC100 to connect to Vegas 6c.
    The ADVC is ok as it works on another machine.
    Driving me nuts.
    All settings in Vegas Options are OK.
    It tells me “no device connected” in the vegas capture prog.
    Has anyone else had this problem. Is it a common one?
    Any advice is appreciated.
    Thx
    System-
    Processor
    Model : Intel(R) Pentium(R) 4 CPU 3.00GHz
    L2 On-board Cache : 1MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector, 2 threads sharing
    Mainboard
    Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
    System BIOS : American Megatrends Inc. V6.1 on 07.00T
    System : MICRO-STAR INC. MS-6788
    Mainboard : MICRO-STAR INC. MS-6788
    Total Memory : 1GB DDR-SDRAM
    Chipset 1
    Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
    Front Side Bus Speed : 4x 203MHz (812MHz data rate)
    Memory Bus Speed : 2x 203MHz (406MHz data rate)
    Video System
    Desktop Monitors/Panels : 2
    Adapter : RADEON 9550 (DNA 3.2.4.10)
    Adapter : RADEON 9550 – Secondary (DNA 3.2.4.10)
    Imaging Device : Microsoft DV Camera and VCR
    Physical Storage Devices
    Removable Drive : Floppy disk drive
    Hard Disk : ST3120827AS (112GB)
    Hard Disk : ST3200822AS (186GB)
    CD-ROM/DVD : BENQ DVD DD DW1620 (CD 40X Rd, 4X Wr) (DVD 5X Rd, 1X Wr)
    Logical Storage Devices
    1.44MB 3.5″ (A:) : N/A
    Hard Disk (C:) : 20GB (15GB, 75% Free Space) (NTFS)
    Disk4_vol1 (D:) : 186GB (90GB, 48% Free Space) (NTFS)
    Hard Disk (E:) : 92GB (829MB, 1% Free Space) (NTFS)
    051116_1616 (F:) : 75MB (CDFS)
    FireWire/1394 Controller/Hub : VIA OHCI Compliant IEEE 1394 Host Controller
    MultiMedia Device(s)
    Device : Realtek AC’97 Audio
    Operating System(s)
    Windows System : Microsoft Windows 2000 Professional (Win32 x86) 5 (Service Pack 4)
    Network Services
    Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC
    Jeremy Rochefort replied 20 years, 8 months ago 4 Members · 5 Replies
  • Geoffrey Mee
    December 12, 2005 at 7:16 pm
    I just tried capturing with Vegas 5d…no better- a big zero.
    So maybe its the firewire card, or is it the mobo? The FWire cable’s ok.
    What checks can I do on the card.
    Thx geoffjak
  • Edward Troxel
    December 12, 2005 at 7:41 pm
    Can you try connecting a camera? See if the card recognizes that. You could always install a new card to help see if it might be a card issue.
    Edward Troxel
    JETDV Scripts
  • Peter Wright
    December 13, 2005 at 12:41 am
    Have you tried disabling device control – maybe Vegas is looking for a camera/tape ..
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Geoffrey Mee
    December 13, 2005 at 4:55 am
    Thanks for the replies .
    Device Control? Didn’t work. Got a guy coming in today.I’ll pass on what he sees [and fixes I hope].
    Geoffjak
  • Jeremy Rochefort
    December 13, 2005 at 8:03 am
    I’ve had this exact problem when using an ADVC with onboard firewire adapter.
    If you have access to a seperate PCI firewire card, I would try that.
    Cheers
    Jeremy
    MJ Productions
    MJ Productions
