Activity Forums Broadcasting ADVC 1000 problem
  • ADVC 1000 problem
    Posted by Paul Redgrove on November 5, 2009 at 8:27 am
    Hi All
    I’ve borrowed a colleagues Grass Valley ADVC 1000 to send pictures from my FCP on MacBook Pro via SDI to a broadcast monitor and on. Problem is I can’t get anything except noise up on the monitor. I know images are going down the firewire as I tested it with a camera and the ADVC has picked up a signal/stream. Is there some basic procedure I’m failing dismally to adhere to? I don’t have a manual but know it works as it has in the past…
    Cheers
    Paul
    Paul Redgrove replied 16 years, 10 months ago 2 Members · 4 Replies
  • Baz Leffler
    November 6, 2009 at 12:08 am
    Have you got the ADVC1000 set to DV-SDI? (right hand side button). It should display DV timecode in the display window.
    Baz
    What would I do without the ‘UNDO’ button!!!!
  • Paul Redgrove
    November 6, 2009 at 8:11 am
    Hi Baz
    Yup and it generates a timecode and indicates a stream with audio…infuriating as I know it works!
    Cheers
    Paul
    Paul Redgrove
  • Baz Leffler
    November 7, 2009 at 2:35 am
    Paul – I have a MBP and an ADVC1000 in my facilities here. If you haven’t sorted it out yet I can hook them up here and see if I can replicate your problem.
    Just let me know.
    Baz
  • Paul Redgrove
    November 15, 2009 at 1:47 pm
    Hi Baz
    Never got the damned thing to work. Tried everything. Had it running through firewire onto camera no problem. Thing is my edits suffered form cutting wihtout a monitor and if it’s a persistant problem then I’ll have to look at other setups…although my desire for a fully functional mobiel FCP with Black Magic, monitor etc etc continues to fall on deaf ears…
    Cheers
    Paul
    Paul Redgrove
