Activity Forums Avid Media Composer ADVAudioDev: Failed to set DIO audio sample rate
  • ADVAudioDev: Failed to set DIO audio sample rate
    Posted by Larry Morales on November 3, 2011 at 9:35 pm
    Hi all,
    I recently upgraded to MC 5.5.3 from 5.5.1 and now am experiencing an issue I’ve never had.
    When I searched it the newest item that came up is from ’08. It is, as the subject suggests…
    ADVAudioDev” Failed to set DIO audio sample rate.
    I’m on a Mac OS 10.6.8, Dual 2.8 Quad Core Intel Xeon with 4GB 800 MHz DDR2.
    I’m connected to a Matrox Mini for monitoring purposes.
    As of yesterday, everything worked well, today I cannot monitor through the Matrox Mini, I get the spinning Beachball with the Error message and unless I use the 1394 configuration, MC crashes.
    It occurs throughout all my projects so it’s not really an audio issue.
    Any ideas?
    tvmambo
    Larry Morales replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
