Activity Forums Adobe After Effects Advantedge crashing AE CS3
  • Advantedge crashing AE CS3
    Posted by Ian Schmoel on August 1, 2007 at 5:14 pm
    Has anyone had problems using Ultimatte’s AdvantEdge with AE CS3 beta?
    The plug-in works fine within AE but when I go to render it crashes and gives me the following error:
    After Effects error: crash occured while invoking effect plug-in “AdantEdge”.
    Thanks in advance,
    Ian
    Tim Hedegaard replied 19 years ago 4 Members · 3 Replies
  • Danny Princz
    August 2, 2007 at 6:07 am
    i was told that there would be an update to adventedge somewhere around the time CS3 ships… whatever that means
    who is that masked man…
    https://www.exposedideas.com/
  • John Mclane
    August 7, 2007 at 2:26 pm
    I have this really anoying problem myself, even on the AE 7 version ! It’s driving me nuts ! Anyone has found a solution ?
  • Tim Hedegaard
    September 7, 2007 at 11:21 pm
    Just a quick note to let you know that the Intel Mac-compatible version of Ultimatte AdvantEdge is now available.
    If your system was Intel Mac-based, that is why it was causing a crash. Please visit https://www.Ultimatte-Software.com to download the new version. If you don’t have the most recent version, the full software or an upgrade can be purchased online.
    The new version ONLY corrects the incompatibility with Intel Mac-based systems. If you are not using an Intel Mac-based system, this update will likely not solve your problem.
