Activity › Forums › Apple Final Cut Pro Legacy › Advantages of Pro Res?
  • Advantages of Pro Res?
    Posted by Icsproducer on September 13, 2007 at 9:28 pm
    I am cutting a doc on an Arctic Leadership Adventure.
    We shot all the beautiful cover in DVCPro HD 720 24p to P2 cards
    and all of the inteviews were shot to miniDV tape 24p.
    After reverse telecine the mini DV looks great in a DVCPro 24p sequence.
    What if any are the advantages of using a Pro Res sequence?
    -any benefit to the uprezed miniDV?
    David
    Technical Director
    Inuvialuit Communications Society
    Inuvik NT
    Sean Oneil replied 19 years ago 3 Members · 5 Replies
  • Sean Oneil
    September 14, 2007 at 1:02 am
    It is a higher quality codec. Higher bitrate and more advanced compression techniques.
    You won’t see some kind of major improvement on your DV footage (if any improvement at all). The advantage is that each generation loss will take less damage. By the time your video is broadcast, on the web, or on a DVD, it will look better. This is especially important if you are doing a round-trip to Color, After Effects, etc. Each time you re-render it, it takes a hit. The damage is less when using ProRes (and there’s no damage at all using uncompressed).
  • Gerard Tay
    September 14, 2007 at 2:48 pm
    Nice answer. Digitally (even in the world of audio), you only lose quality if you export at a lower resolution, or the signal goes through analogue/digital conversion (via composite/component transfers). The beauty of digital is lossless transfers. But of course, it’s impossible to gain quality via increasing the resolution once you have compressed it somewhere along the line..
    hmm… rendering compromises quality? That’s a thought to ponder…
  • Sean Oneil
    September 14, 2007 at 6:16 pm
    [strypes] “hmm… rendering compromises quality? That’s a thought to ponder… “
    Uhh, yeah. You’ve got a lot to learn my son :).
    Any lossy codec is just what it says. ProRes is slightly lossy. DVCProHD is more lossy. DV and HDV are extremely lossy.
    Like Dave said, only Uncompressed and lossless are “lossless”.
    Rip a CD to MP3 using iTunes. Then burn it to a CD. Now rip that new one. Repeat one more time. It will sound like absolute like garbage.
  • Gerard Tay
    September 15, 2007 at 2:15 pm
  • Sean Oneil
    September 15, 2007 at 5:00 pm
    [strypes] “But, my question here is… if you import a clip at dvpal (via dv stream), because it’s recorded on mini dv, which is dvpal… you add some effects in final cut, and render, does it go through a 2nd dvpal compression?”
    Yes.
