Advantages of Breakout Box?
im new here, so sorry for my stupid question.
I am editing on a Macbook Pro for Broadcast and connect an external monitor via HDMI-out directly to the macbook.
I am able to calibrate the monitor via colormunki display and use it with Premiere and Avid to monitor my material.
When Editing with Avid, I can set the color space to REC709 – the monitor has 99 Percent sRGB – so it should be perfect for broadcast use.
In Europe I am using PAL with 25p or 50i.Now I am thinking to switch to Davinci Resolve – so I will need a Breakout Box.
I just want to know: Is a box like the Blackmagic Ultrastudio Monitor just useful for Davinci Resolve or do I have any advantages while editing with Avid or Premiere?
Is editing, monitoring or rendering faster?
Is color correction more accurate?Thanks a lot!
