Activity Forums Apple Final Cut Pro Legacy Advanced pulldown removal problem
  • Advanced pulldown removal problem
    Posted by Mccaincow on September 6, 2005 at 3:23 pm
    I am editing in 24p and All the clips have been fine until I came across one clip that was digitised as 29.97, for whatever reason. When I try to remove the frames using the pulldown removal it gives me an error from a breat in the cadence near t. Is there anything I can do to salvage this clip and remove these frames?
    Mccaincow replied 21 years ago 1 Member · 1 Reply
  • Mccaincow
    September 6, 2005 at 3:29 pm
    I took the clip to Cinema tools and just told it to confrom to 23.98 even though it is already a 23.98 clip. Once the clip is conformed, which takes a second it when offline in FCP. Then I reconnected and everything is Fine!
