Activity Forums Apple Final Cut Pro Legacy advanced pulldown removal PROBLEM
  • advanced pulldown removal PROBLEM
    Posted by Kat Nofs on February 23, 2007 at 2:51 am
    I shot 24pA on the dvx100a and captured using the advanced pulldown preset and my sequence setting is at 23.98. When I drop it into my timeline, there is a red render bar. I was told you shouldn’t have to render when you captured the way I did.
    I wanted to recapture in 29.97 and remove manually, but heard that will make it interlaced.
    Any suggestions or answers would be appreciated.
    Thank you, Kat
    Jeremy Garchow replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    February 23, 2007 at 5:31 am
    BE sure to select the proper easy setup (Advanced pulldown removal) and then make a new sequence. Put your clips in to this new sequence. Blow away ‘sequence 1’.
