Activity Forums Adobe After Effects Advanced pressure waves + Sapphire (very cool) Need help
  • Advanced pressure waves + Sapphire (very cool) Need help
    Posted by Bart Straman on May 13, 2008 at 9:24 pm
    hi there all,
    I’ve got a thing to make, seen it on the gen-arts website here in the first 10 seconds or so:
    https://www.genarts.com/genarts-demoreel-qt-small.html
    (home page gen-arts and then demo-real 2007 on the left).
    You see the big massive pressure waves comming out of those ghettoblaster speaker cones!
    now this is an extremely beautifull effect, but i want to recreate something similair (also using sapphire if possible).
    in the shot you see circles(pressure wave) that begin small and and big, the circles (pressure waves) have white rings with low opacity. between the rings there is a opague piece connecting the the upcomming ring and that below. (like a cone with bottom and top highlighted).
    both displacing the layer(video shot) behind it, so my question how to create something similair.
    (the basics then, not the fancy shiny glitters and sparks, sapphire can handle that, if there is a sapphire pro here, mayby some tips can come in handy. other tips as well!)
    using a combination of radio waves(sending radio waves in a cone shape form?) and displacement mapping is the key mayby, but still can’t figure out how, cause displacment uses black and white pixels.
    the glow on the bass cone is not a problem, the flying sparkles you see(between the pressure waves) is a different story, but I thing after some trials that won’t be a problem.
    let me know what comes to mind for creating this cool thing,
    Thanxs!
    Bart
    Bart Straman replied 18 years, 3 months ago 2 Members · 2 Replies
  • Grant Swanson
    May 13, 2008 at 9:42 pm
    Hi Bart,
    It’s been a while since I’ve done something like this, but try using the following effects (they all come with Sapphire): Warp-Puddle; Distort; and Distort Chroma.
    Try combining one or two of these in a precomp along with the Levels and Hue & Saturation effects (using your plate as a guide layer.) A few keyframes in the color and contrast as well as the different distortions should give you the results you are looking for.
    Hope that helped!
    -Grant Swnson
    https://videoapex.blogspot.com/
  • Bart Straman
    May 14, 2008 at 10:19 am
    hi Grant (and others again)
    Thanxs for pushing me in the right direction, a combination off those you mentioned get’s me a little closer, but there is a problem. In the movie-clip you see 3D pressure waves, and with warp-puddle there are only 2D displacement waves with no DEPT. can you mayby by more specific with the phrase (“plate as a guide layer”), I’m quite new to sapphire and I’m not sure how to give the puddlewaves any dept
    anybody an idea how to get this to 3D, it would be so fine 🙂
    thanxs!
    Bart
