Activity Forums Adobe After Effects Advanced Lightning Circle
  • Advanced Lightning Circle
    Posted by Oliver Harrison on March 27, 2016 at 3:38 am
    I have an animation i’m trying to replicate, but I’ve encountered some issues in the advanced lightning. I am trying to simply get a ball with lightning streaming randomly from different points on the circumference of the circle. Here is the picture:
    I think it is “anywhere” lightning, but I can’t figure out how to get it to branch with segments equal in width, and completely randomly. How would I animate it to get the interior lightning to move?
    Oliver Harrison replied 10 years, 5 months ago 2 Members · 4 Replies
  • Kalleheikki Kannisto
    March 27, 2016 at 7:53 am
    Make a circular mask on a solid, set it to subtract, and precomp the layer, then add the effect. Use alpha barrier at 100% to make the lightning stay inside the circle. You can wiggle the start point to get it to animate.
  • Oliver Harrison
    March 27, 2016 at 1:38 pm
    Do I use the anywhere strike setting? Because then the problem is that it originates from the center, as opposed to the circumference of the circle.
    March 28, 2016 at 9:37 am
    It will originate from the origin point, so put the origin point somewhere near the edge.
  • Oliver Harrison
    March 28, 2016 at 9:07 pm
    Worked like a charm! Many thanks!
