Activity Forums Apple Final Cut Pro Advance search in timeline
  • Advance search in timeline
    Posted by Chemi Ferreiro on July 19, 2018 at 11:24 am
    Hello everyone!
    I’m trying to come up with a formula to search for clips with certain criteria within the ‘timeline’ (project)
    For example: I’m trying to create a list of all clips that have been SCALED, RETIMED or REFRAMED to pass it on to the DCP lab for processing my film…
    Any ideas other than manually going through the entire timeline taking notes?
    Thanks in advance
    Tony West replied 8 years, 2 months ago 4 Members · 4 Replies
  • Michael Hancock
    July 19, 2018 at 1:40 pm
    This might help:
    https://intelligentassistance.com/producer-s-best-friend.html
    Michael Hancock
    Editor
  • Jeremy Garchow
    July 19, 2018 at 5:14 pm
    I think a good way to do this woudl be to add a subrole to the clips that you need to process.
    No matter the master role, you could add a subrole under that master role. Let’s say that Subrole is “Special_Process”.
    So, under each master Role (like Video, VFX, etc) you’d make a subrole called “Special_Process”.
    Then you could search for the word “Special_Process” under the clips menu in the timeline index and it would return all the clips that had that Subrole.
    From that list, you could select them, if you’d like, or screen grab the filenames, or do anything else you may need to do.
    So yes, you’d have to go through and find each clip, but it would make any future edits/changes much easier. You’d have to remember to set the subrole when you add clips to the timeline, though.
    Jeremy
  • Chemi Ferreiro
    July 19, 2018 at 5:27 pm
    Thanks a lot!!! I’ll be putting these tips under test tomorrow and will report back…
  • Tony West
    July 20, 2018 at 3:46 am
    You could also type “Retime” into the notes in the inspector and that would come up in clips in the index also, but you would still need to go through and make those notes. I can’t see it taking that long to do that.
