Activity Forums VEGAS Pro Adtech’s Instant Video MPX a-to-d converter
  • Adtech’s Instant Video MPX a-to-d converter
    Posted by John Gregoriades on November 17, 2005 at 3:54 pm
    A friend without much money would like to move VCR videos into his PC, to eventually make DVDs. He is in Europe and uses all PAL.
    This hardware apparently connects to a USB port and is an analog-to-digital converter, for around $70 which is wihin his price range.
    Any knowledgeable opinions on this, please? (Does it work, reasonable good quality, etc.?) Any other low-cost options (remember his low budget!)
    Thank you in advance,
    John
    John Gregoriades replied 20 years, 9 months ago 3 Members · 4 Replies
  • Edward Troxel
    November 17, 2005 at 5:42 pm
    The best advice you can give him: STAY AWAY from USB devices for capturing video. Stick with firewire and a convertor/camera/deck.
    A firewire card is cheap. The most expensive component will be the convertor (unless he already has a miniDV camera that supports pass-thru). But you ARE talking more than $70 to gain several advantages: Standard capture to standard DV-AVI files, easy setup, better quality, fewer headaches trying to make things work or keep things in sync (usually a BIG problem with USB solutions)…
    Edward Troxel
    JETDV Scripts
  • John Gregoriades
    November 18, 2005 at 4:23 am
    Edward,
    Thank you for your prompt reply. I believe his primary use will be to take ordinary VHS video (PAL), and essentially digitize it and save it in the PC; eventually to convert to DVD.
    Any recommendations (on the inexpensive side?)
    thank you,
    John
  • Allen Zagel
    November 18, 2005 at 10:43 am
    The Canopus ADVC-100 is about $100 and is what you’re looking for.
    Allen
    My web site features;
    China, China Railways and music.
    https://www.azagel.com
    Video site;
    https://www.asxvideo.com
    NEW! Shanghai MagLev DVD.
  • John Gregoriades
    November 18, 2005 at 4:20 pm
    Thank you, Allen. So, it’s Canopus! I’ll check its specs out on the web.
    John
