Activity › Forums › Apple Final Cut Pro Legacy › adstream and apple compressor
Posted by Harald Salaun on March 5, 2009 at 11:40 amHi!
Does anybody know if there is a preset existing for compressor to convert to adstream’s (adstream.com) mpeg2 specifications?
Many thanx in advance
Harald 🙂Jeremy Huff replied 16 years ago 3 Members · 4 Replies -
Chris Poisson
March 5, 2009 at 5:27 pmHarold,
You didn’t list the spec, but I’m guessing it is an mpeg2 program stream, for which you would need Episode Pro.
I don’t think Compressor can do this.Have a wonderful day.
Harald Salaun
March 5, 2009 at 6:16 pmHere are the specs:
Standard: 625/50
Aspect Ratio: 4:3 / 16:9 FHA (for certain stations only)
Chroma: YUV 4:2:2, RGB legal 100%
Audio Levels: Peak audio – 09 DBFS
VITC (if applicable): lines 19 and 21File delivery
Format: MPEG2 422@ML
Bitrate: up to 50Mbp/s SD
Gop Structure: I Frame only
Audio: MP2 384kb/48kHz
Bars and Tone: 5’ EBU Bars
Pre Roll: 20’ (5’ EBU Bars and tone, 10’ Black, TVC, 5’ Black)
Post Roll: NO Freeze – 5 sec black only -
Chris Poisson
March 5, 2009 at 9:37 pmHmmm, looks like my guess was correct, yes, I believe only Episode can make these.
Jeremy Huff
September 14, 2010 at 8:05 pmWhat is wrong with Sorenson Squeeze?
I believe this will work too.
