Activity Forums Adobe After Effects Adrew Kramer reflection effect on Ivig 3D text
  • Adrew Kramer reflection effect on Ivig 3D text
    Posted by Julio Crespo on August 24, 2006 at 10:20 pm
    I make the tutorial of the reflection from adrew kramer, very good thing. Also i wish to make the reflection with a invig 3d text, but I try a lot of way and dont look fine. The camera movement dont match with the text and some other troubles. Does anyone have an idea to do that.
    Julio Crespo replied 20 years ago 2 Members · 3 Replies
  • Justin Productions
    August 25, 2006 at 1:37 am
    Hm…
    I don’t have a lot of time right now but…did you checked “Comp Camera” in Invig’s Effect Window?
    Another way to do it would be to make your 3D text, animate it, precomp/render it with an Alpha (only text, if you rendered it) then to import it in your comp, place it underneath your actual 3D text and play with the ramp/blur effects. Even the Smear effect from Pete’s Plug-Ins would probably work to do the blur (you’d probably have to keyframe the Smear position center point to your on the bottom of the “reflection” text).
    Another way…would be duplicate your 3D text in Invig, put it under your upper (main) text, use a gradient as the layer map on your text…but you wouldn’t be able to add blur to it.
    I’m sure there are plenty of other ways to do this but I just can’t think of them.
    Good luck.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Julio Crespo
    August 25, 2006 at 7:09 pm
    I try all those ways but not work, when the text have no rotations in Y axis look fine, but when I roatate the text or the cam its no match
  • Julio Crespo
    August 25, 2006 at 7:16 pm
    i duplicate the invig layer and rotate 180 the x axis on invig sets properties THanks
