Activity Forums Avid Media Composer adrenaline error database
  • adrenaline error database
    Posted by Drew on July 7, 2005 at 5:54 am
    has anyone created or come across a full blown listing of errors with/without diagnostics for the errors for the adrenaline or avid nle’s in general? hard to get to anyone at avid for help, and I would be more than willing to start something like this and post it online for fast access for everyone out there. Man this would be somethin. Today was error day.
    Drew
    Andy Garcia replied 21 years, 2 months ago 3 Members · 2 Replies
  • R. Hewitt
    July 8, 2005 at 3:14 pm
    You could try: Avid Support Knowledgebase.
  • Andy Garcia
    July 8, 2005 at 4:26 pm
    have you tried dumping your data base. If that doesn’t work. Does it keep coming up saying something about problem with one of them.
    what i did when i had this problem is…….. wait for it, this will take you while.
    go into your drive and put an x in the omfi folder create a new folder and name it what ever your old omfi folder was call.
    then drag (250 at a time) your media over to this new folder. you will need to boot up the avid programme each time you make a transfer.
    if you reduce the avid programme each time you come to make the transfer it will reduce the boot up time.
    also only transfer media NOT the old data bases or creative folders.
    In doing this for some reason the avid can create a new data base file and also it will find any currupted media files that also might be causing you problems.
    This does work, but can take a bloody long time as I found out last week when I had to transfer 22,000 files.
    Note for self: must partition Medea terra drive into to 4.
    good luck!
    PS. if this isn’t what you are having a problem with, then I haven’t got a clue.
